C5 vibration help
waynedance
- x 8
C5 vibration help
Now not sure how to describe this one, I have a sort of vibration or shake as if one of thw wheels was buckled but they are all fine. It is worse with hard acceleration but also if pulling away slowly say at 1800-2000 revs. The feeling is as if the engine was misfiring but checked and engine seems to be running fine and revs smoothly at standstill.
The car has had a replacement engine, clutch, duel mass, air mass meter. I did notice a leak on the inner driveshaft boot on drivers side which had lost grease so while it was removed doing the turbo i atempted to plug the hole up.
Could the driveshaft be causing my shake/vibration? Car will cruise fine at 70 with cruise on but do still feel a little shake on the car.
Thank you.
Thank you.
Volvo S80 D5.........
SaabC5
Re: C5 vibration help
Get the front in the air and check the front wheels for play, could be a duff bearing or more likely a wobbly track rod end.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
taffy
or tyre balancing maybe? wheel
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
waynedance
- x 8
Wheel balancing done, could a faulty clutch or flywheel cause this? or would it be all the time?
Stewart(oily)
- x 35
Cured an oscillating vibration on a Xantia by replacing a driveshaft, after running out of ideas completely.
waynedance
- x 8
I am thinking drive shaft, it is as if the wheel is egg shaped or wheel nuts loose. Can not feel much on the steering wheel, last time all ball joint were check all were ok.
The bottom ball joints, arms, rear bushes drop links were all changed last year and as said new clutch and flywheel this Feb. When I refitted the drive shaft in Feb it was a pain to get seated right and get the small bolts in the middle section back in.
qprdude
- x 14
Hope it's not the DMF. I had a similar problem with a Renault 5 (going back a bit) and a new driveshaft sorted it.
Rick.
2013 Citroen DS 5 D/Sport
waynedance
- x 8
Does anyone know if the drive shafts were different between models, ie does 1.8 fit 2.2hdi?
Thank you.
Thank you.
- x 1493
Sadly not... 2.2 appears to have a specific shaft. Lesser engines use the BE4R box and these are differnt again, as are shafts fitted to the auto models.
ML MANUAL GEARBOX
01
3272 EJ
01 DRIVE-SHAFT NEW
LEFT
MARKING 8LN85
- INJECTION ES9J4S
01 LEFT
- DW10ATED TURBO DIESEL
01 LEFT
- DW10ATED TURBO DIESEL PARTICLE FILTER
3272 RA 01 LEFT
- DW12TED4 TURBO DIESEL
02
3273 EJ
01 DRIVE-SHAFT NEW
RIGHT
MARKING 8LN86
- INJECTION ES9J4S
01 RIGHT
01 RIGHT
3273 NY 01 RIGHT
Citroen prices will make you choke on your cornflakes
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00003272RA DRIVE-SHAFT NEW 330.11 GBP 396.13 GBP
00003273NY DRIVE-SHAFT NEW 512.80 GBP 615.36 GBP
ML MANUAL GEARBOX
01
3272 EJ
01 DRIVE-SHAFT NEW
LEFT
MARKING 8LN85
- INJECTION ES9J4S
01 LEFT
01 LEFT
3272 RA 01 LEFT
02
3273 EJ
01 DRIVE-SHAFT NEW
RIGHT
MARKING 8LN86
- INJECTION ES9J4S
01 RIGHT
01 RIGHT
3273 NY 01 RIGHT
waynedance
- x 8
Dam the 2.2hdi...........
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... AQ:GB:1123" onclick="window.open(this.href);return false;
Seen this on ebay but no answer yet from seller.
taffy
I know The 90hdi and The 110hdi are different size drive shafts....wen I done my clutch I messed up and acidently split The shaft losing a lot of The neadle bearings...went to scrappy and got wat I was told was The right one and got bk and it was thinner...but took out The neadle bearings which were bout 1mm shorter and rebuilt origional...
qprdude
- x 14
Ho Ho, those needle bearings are a bloody nightmare. I did the same with the Renault one. Luckily the whole lot was dirt cheap for the little car in those days.taffy wrote:I know The 90hdi and The 110hdi are different size drive shafts....wen I done my clutch I messed up and acidently split The shaft losing a lot of The neadle bearings...went to scrappy and got wat I was told was The right one and got bk and it was thinner...but took out The neadle bearings which were bout 1mm shorter and rebuilt origional...
Rick.
taffy
Ah it was a tricky job lol
yea we could get anything for a tenner in them days lol!
waynedance
- x 8
new shaft ordered just hope it sorts out my problem.
Oh paid £91+vat (trade)
taffy
Hope it solves it mate
