cheapest recharge?
Harlequin
- x 24
cheapest recharge?
Im after a cheap top up for my aircon...it blows cool but not icy cold. Does anyone know where is good and cost effective or what about those home kits?
Simon
steelcityuk
Re: cheapest recharge?
Look around for offers from the likes of quik fit and such. Try to find one that offers a no improvement no pay guarantee. Such places aren't ideal if you've got problems but the recharges are as cheap as you can get. Also if the system leaks under a vacuum test they won't try to fill it and shouldn't charge you.
Steve.
Steve.
not applicable
Xaccers
- x 186
Sign up to Groupon and Living Social as they often have deals for £14
Or wait until winter and most places knock 50% off.
DIY sphere tool
DIY sphere tool
Harlequin
- x 24
cheers Xac , just signed up to groupon , cant find a way to search it though? and not heard of living social so will go look!
Simon
Harlequin
- x 24
what pressure should the system be at? now mine has been recharged it seems to be in the green @ 35psi on a really hot day otherwise its at 25 psi when running! blows cold though
Simon
MJM
What car is it? I've a PDF file here that covers Xantia XM and Synergie aircon pressures/temperatures. It also covers loads of other stuff, brakes,engines etc. (It's 310 pages!) If you want a copy then then post here and we'll work out a way via admins to get you one.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
Harlequin
- x 24
MJM
O K
Here’s some data.
Checking is done with the engine at 2500rpm, fan on full speed and ventilation set for air to foot and dash vents. All doors and windows closed, flap set to fresh air, not recirculation.
Pressures
High pressure
Ambient temperature 15/20 degrees c 13 bar +/- 3 bar.
Ambient temperature 25 degrees c 16 bar +/- 3 bar.
Low pressure
Ambient temperature 15/20 degrees c 1,8 bar +/- 0,3 bar.
Ambient temperature 25 degrees c 2,5 bar +/- 0,3 bar.
Temperatures (measured at dash central vents)
Ambient temperature 15/20 degrees c vent temperature 8 degrees c +/- 3 Note set fan speed to 2 at this ambient.
Ambient temperature 25 degrees c vent temperature 12 degrees c +/- 3
You say that are seeing a pressure of 35 psi on a hot day. That’s 2,4 bar. It seems about right.
The temperatures are easier to check.
That's about all I have on the temperatures and pressures. Ask if you need more information, I'll try to help.
Here’s some data.
Pressures
High pressure
Low pressure
MJM
Harlequin
- x 24
