Xantia service interval display ?
Mandrake
x 694
Unread post by Mandrake »
Hi All,
Since I've had my Xantia V6 the service indicator that appears during key on has always flashed zero, so as I completed an engine oil and filter change on the weekend (and have done fuel filter and air filter quite recently) I decided it was time to reset the service indicator which is done by holding down the reset button for a while while turning the key on.
What has me slightly puzzled though is that the only option seems to be 12,500 miles, which seems far too long to me ? Certainly too long for an oil and filter change, so what exactly is the 12,500 mile interval for ? Is it only meant for dealer services during the warranty period, if so what is it that's being checked or done at 12,500 mile intervals ?
Doesn't seem particularly useful to me, I was hoping the interval would be appropriate for oil and filter changes to help me remember to do them on time... :twisted:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Ben82
x 7
Re: Xantia service interval display ?
Unread post by Ben82 »
the C5 V6 one is 30,000km so over 18,000miles... I believe the service book reckons 30,000km or 2 years for service intervals. Not that I'd stick to it :)
I did notice when I was fiddling with the lexia, that there did seem to be a configuration option that allowed you to change it (the interval that is, not the countdown). So possibly something you could change to suit your needs.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Mandrake
x 694
Yikes, 18,000 miles for oil and filter ? Even 12,500 miles is way too much. I don't think there's any option to change it on the ES9J4 Ben, I've been over the ECU's in the car with a fine tooth comb and would have noticed such a setting by now. ;)
I wonder if the counter also changes to zero after a certain number of starts, or a certain period of time, or whether it purely counts mileage ?
Simon
1978 CX 2400
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's ancient technology. Don't imbue it with ill-deserved sensibilities.
rory_perrett
Unread post by rory_perrett »
The service indicator just counts the miles. It is also a function of the dash module, I'm using the dash module from a 2.1td (6,500 miles service interval) in my HDi (originally 12,500 service interval) so it is showing a 6,500 mile service interval. I will have to investigate whether I can reprogramme it with my Lexia.
Mandrake
x 694
As far as I know a Lexia can't communicate with the dash module of a Xantia, as it doesn't have an ECU that presents itself on the diagnostics bus. I think you'll find its very simplistic and the service interval is hard wired in the chip or at least with a jumper on the board! :)
Simon
1978 CX 2400
rory_perrett
Thanks Simon, I won't bother investigating and save myself hours of endless frustration - I can get a bit obsessive once I've started this sort of thing
Regards
Chris570
x 36
Unread post by Chris570 »
the HDi and V6 are set to 12.5k so it's not different between models, I change my oil every 6k so i change it halfway through it's countdown
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
