c5 hdi facelift 07 air con climate probs
ststech
Unread post by ststech »
i have a c5 2007 1.6hdi vtx+
the problem is no a/c also the drivers side climate only blows cold (not refrigerated air) luke warm and you cannot adjust it if you put it to max heat it stays the same
pasengers side gets hot when adjusted but no a/c the compressor doesnt start there is refrigerant in the system
any help appreciated
2007 Citroen C4 grand picasso 2.0 hdi egs exclusive silver
1993 Citroen bx tzd estate silver
2008 Citroen C6 2.7hdi exclusive storm grey
x 3296
Re: c5 hdi facelift 07 air con climate probs
This is a known problem, and is due to the flap motor not having a long enough shaft;
http://www.frenchcarforum.co.uk/forum/v ... or#p370262" onclick="window.open(this.href);return false;
ststech
would this cause the a/c compressor not to engage ?????
x 3296
Pass on the a/c bit. I don't have any C5 experience. I posted the link because I remember reading about the problems. Sorry I cannot help further.
triumphtoledo
Unread post by triumphtoledo »
A/C System discharged is my (un)educated guess.
Facelifted C5s inherited the Peugeot 407 heater box and so it won't be the heater motor cog but, perhaps, a broken plastic flap within the box itself. Reinforced flaps are available from Peugeot/Citroen, costing £70.00 for a kit.
R
