Fuel problems... XM
Chris570
x 36
Fuel problems... XM
Unread post by Chris570 »
Seeing as all XM owners are lovely I'd like some words of advice (to do with the car ;) )
I've got 2 problems with the fuel tank/gauge on my Mk2 XM...
Problem 1... The fuel gauge never reads below 1/4 of a tank and the trip computer will never go below 50 miles left (the fuel light never comes on either) and I know that the tank was empty as I ran out of fuel! I presume then that the level sender must be at fault here, my only assumption is that the rod must be bent as it takes forever to come down from full... is this the only probable cause? (before i take the sender out)
Problem 2 ... Filling the car up.... This is a complete pain considering it's a V6, if it was a diesel it would be less of a concern. As the tank gets more fuel in it the pump will clock off more frequently. So if the tank is empty i can put 10l in and the pump will click off, there will then be a gurgle and then i can put 9l in, then click, gurgle... and so on. This is annoying. I presume the tank ventilation system is at fault /blocked, any pointers?
Cheers :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Re: Fuel problems... XM
Unread post by citroenxm »
New ones on me chris...
(Jim if you read this.. see i dont know a lot on these or at least this is something i dont know.. lol :-D ..chris.. dont ask :lol: )
I would of hazzard a guess at a bent sender arm if someone previously has had the thing out of the tank..
Clicking filler hose's are a pita.. not sure there..
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
My thinking on the clicking is that the air in the tank isnt finding a way out when the fuel is being pumped in. Do you know how/where it vents?
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
citroenxm
Fallen Hero
x 70
From what ive seen much like the xantia.. along the filler neck area..
A very sad...
1994 XM 2.1 d auto
x 8423
I get on mine, if you really try to fill it to the limit it will spit back and soak you in petrol but never had your problem Chris...
Paul, LOL :-D :lol:
Chris570
x 36
sometimes mine will spit, so rude
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Mandrake
x 695
Unread post by Mandrake »
Seems to me that you've diagnosed both your problems yourself - bent sender arm and blocked vent pipe! I'd go with both of those even though they've never happened to me... :lol:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's a blocked cat.
Mandrake
x 695
Re:
addo wrote:It's a blocked cat.
:rofl:
Simon
1978 CX 2400
Chris570
x 36
Re:
I was hoping not.
I'll change my gearbox oil just in case though 8-)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
x 95
So, you're saying - when you put your nozzle in, sometimes it's all over too soon?
Chris570
x 36
Re:
addo wrote:So, you're saying - when you put your nozzle in, sometimes it's all over too soon?
Yes, and I try try and try again but it often leaves at least one party unfulfilled.
Car's not much better
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
x 95
Well, it's not so bad as for this fella:
x 8423
^^ I LOL'd a lot... nearly as much as the people filming that episode...
taffy
Unread post by taffy »
Lmao! Wat did they do to The xm mk2? Didn even know it existed..
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
