welder req in kent area
sym
hi, can anybody recommend a good welder preferbly in kent who could weld my outer sills on my peugeot 406, theyve rotted at the front drainholes, id like them done to mot standard so it can pass, its not due till next year but i dont want to leave it to the last minute, thanks in advance, lee
- x 3298
Re: welder req in kent area
I wonder if Citronut could help? He is based in East Sussex.
- x 94
were in Kent are you located,
and how far has the tin worm progressed
Regards, malcolm.
sym
hi, im in the medway towns but willing to travel, its not too bad, maybe about 10" on either side, i cut the rot out to stop it spreading too far & also welded a plate over each hole, its not the best of jobs but its better than it was, the welder i used was a bit s**t & i had to do it outside with temps about 2 degrees, thanks lee
- x 94
pm sent
Regards, malcolm.
