All sorted now :-0
Had no gas in it what so ever.
Took it to local place by me 40 quid to pressure test and refill :-00
Now froze in car
C5 Aircon
addo
- Sara Watson's Stalker
- x 95
Re: C5 Aircon
Where had the gas escaped?
ej2095
Re: C5 Aircon
ment to be topped up every 2 years.
But had the car in march so not a clue when it was last checked
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
addo
- x 95
SaabC5
Re: C5 Aircon
Yup, filling it up is just a temporary fix. You should have done a dye test done to identify where its leaking from.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
ej2095
Re: C5 Aircon
Had a leak test done on it and it passed
addo
- x 95
Normally, the "quick and dirty" fix is a vac-down, however while this detects stuff like torn O-rings and corrosion holes, it doesn't often detect failing rubber hoses or shaft seals as it pulls the damage tight, sealing it again. The dye - if they added it - will reveal the leaks occurring under pressure (you can buy a cheap UV torch from Fleabay and find the spots yourself).
