EGR Valve - C8 2.2 Hdi
brittleware
Has anyone changed one of these? Any tips? Looks like it's wipers and panel below screen removal necessary?
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Citroen XM 2.0 turbo
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
Monkeyfeet
Re: EGR Valve - C8 2.2 Hdi
Buy a blanking plate from eBay, and never worry about it again.
(It might even run better too)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
brittleware
Thanks - I do think that would be a good option - but how to get to the thing even to fit a blanking plate? Are there any short cuts? Thanks!
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
Monkeyfeet
I'm not familiar with the C8 layout, only the C5 arrangement I'm afraid. In that version it's really easy to get to the egr outlet / inlet manifold junction to put a plate in. If it's anything like the earlier Picasso variant of the Xsara you have my sympathies re egr access. However on the practical side, if you think it would help I certainly wouldn't mind taking some shots of the C5 layout to give you an idea of where things are if access is blocked on the C8????? I'm assuming here that the ancillaries here are pretty similar. Sorry I can't be of more help. Any body out out there done this?
brittleware
Pix would be great, thanks. On the C8, everything behind the front cam cover is totally invisible!
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
- x 1049
Just blank it at the inlet manifold side, on the 16v HDi the pipe goes round the front ?
spider
- x 77
I think inlet blanking is not a bad idea where possible as generally it seems to be slightly easier to get at on most, plus where there is a coolant tube passing through the EGR pipe it will still get this benefit, ie the exhaust will help to warm the coolant a bit quicker.
Some models (not sure which) have the blanking plate with a slotted hole so you can loosen rather than remove the bolts, although I may be thinking of something else.
Blanking it is probably a good idea on most diesel cars though in my opinion as they only coke up, and if / when they stick slightly open all the time due to said gubbins inside them that's when the running issue fun starts.
Andy.
C8misery
brittleware....any luck with this I would like to do mine also...did it work out???
waynedance
- x 8
What are the benefits of blanking of the EGR?
how do you know you need to blank it of?
Volvo S80 D5.........
