citroen relay non starter
kev the builder
hi my 2003 citroen relay 2.0 hdi was running fine i turned the engine off then 5 mins later it refused to start it tries to fire in the first second of cranking but then nothing it seems the injectors are not getting any power,the low pressure pump is working, the engine cranks at over 500 rpm, the high pressure pump has over 200 bar i had the brain read the vans not mine thats beyond help the only codes was an egr fault and the glow plug air temp sensor niether of these should stop it starting,i took the egr valve of 2 years ago and the glow plugs only work at freezing point does anyone have any ideas this is doing my head in and its not easy getting me and my tools to work on my motor bike,thanks kev
- x 94
Re: citroen relay non starter
hi Kev
and welcome
what type of analyser was used to read the fault's/codes,
if it was a generic garage type in might be woth looking in the link below,
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
for a FCF member in your area with a DIS-LEXIA, this being the main dealer ( clone ) diagnostic tool,
quite a few member are willing to plug there DIS-LEXIA in for tea and chocy bicy's
and welcome
Regards, malcolm.
