Xantia speedo
louis1
Xantia speedo
Hi I have a 1998 Xantia V6 auto, and the speedo goes off the clock [:D]when driving fast and hits the tripometre button at the bottem of the clock. The revs carry on going up but the speedo can't, so does anyone know how i can work out my speed e.g speed per 1000 revs in top gear.
fastred
KevMayer
AndersDK
Homer
- x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">This picture is taken on the German Autobahn.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Thanks for that, you had me a bit worried.
It looks like fastred's calculation is a bit 'out' at those kind of speeds. Probably works well at British (snail's pace) motorway speeds. His calculation would give you 180mph at those revs, which is above the possible performance of the V6 Xantia.
240kph works out at around 150mph, which is only a fraction over the supposed top speed which I think is around the 140 mark, so I would guess it is simply the usual error margin built into all speedometers (0 to +10%).
I think your best bet would be to get hold of a GPS system to obtain an accurate speed reading. Because at those speeds, errors due to tyre pressure/wear/size would affect any calculation based on RPM. Or time it over a measured distance.
A bit of a jump from the BX16 I imagine?
[added]
I suppose for a rough estimate you could take the revs at a known speed (say 200kph) and use that to do the calculations.
So if you are doing 5000RPM at 200kph then that gives you 40kph for each 1000RPM. If so then the 6250RPM indicated in your picture would equate to 250kph (152mph, which is within 140 + 10%)
[added]
Homer
- x 16
fastred
