406 Hdi Steering wheel change
patrickgledhill
Unread post by patrickgledhill »
Hi guys, The steering wheel on my hdi has become very worn. Im curious to know if its much of a job to replace it and also if the "newer look" wheel will fit onto my 2000 model
Cheers and thanks
addo
Sara Watson's Stalker
x 95
Unread post by addo »
They're quite easy to remove (albeit usually the centre bolt is very tight), but for safety you should let the car go to sleep before unhooking the battery and working around the airbags. Use a good quality Torx bit and small breaker bar - don't whack the column with an impact driver.
spider
x 77
Re: 406 Hdi Steering wheel change
Unread post by spider »
Leave the nut (maybe a bolt on later models) on a few turns do not completely remove it as if you wiggle the wheel off it may free itself suddenly resulting in loss of pride when it catches you in the face ( :oops: )
Andy.
patrickgledhill
Cheers For that guys, will the leather wheels fit on do you think? be bazaar if they were different i think
addo
x 95
I can't see why they'd change the shaft for one type of wheel to another.
If you're not familiar with how fragile the cockspring is, be careful or you'll clock it up.
patrickgledhill
Yeah thought so, will keep the cockspring in mind, cheers for that
