Xantia TU ?
spider
x 77
Xantia TU ?
Unread post by spider »
Andy was just wondering.
There were some late model (L and M plates) 405's fitted with a 1.4 TU unit (yes really) :oops: that I saw occasionally but they were quite rare. I expect the XU 1.6 was more economical really as poor TU would have a fair bit of weight to shift compared to a slightly larger engine.
Question is did Citroen ever to this to the Xantia ? I cannot say I've heard of one, although I think the 405's were not UK spec even though they were RHD.
Off topic what was more interesting was the small number (I think I've only ever seen 2 or maybe 3) 'R' plate 405 estates. :) Badged as GLX but had the full GTX spec (lovely grey velour interior and both AC + SR etc etc)
Andy.
x 8172
Re: Xantia TU ?
I've seen an R Reg 405 Break Andy... I believe the reason was the 406 Break took a long time to arrive, as did the Xantia Break. It was two years after the Hatch..
I'm not aware of a TU powered Xantia but I do believe there was a 1588cc XU version without power steering. Never imported into the UK though...
spider
x 77
Re: Xantia TU ?
CitroJim wrote:I've seen an R Reg 405 Break Andy... I believe the reason was the 406 Break took a long time to arrive, as did the Xantia Break. It was two years after the Hatch..
Ah OK. That seems odd though on a hydraulic car to not have have a power rack fitted as there's already 90% of the parts already present.
Seemed a very well equipped model at the time, especially as it was near the "end of line" so they tended to fit extra's anyway, reminds me of the last 306's most had a fair bit of equipment fitted.
Yes the 406 Break / Estate did not arrive until late P plate if I remember correctly, and auto's arrived (both 4 and 5 door) around the same time. I *think* it coincided with the switch from keypad to transponder as well but I'm not 100% sure on that. Something tells me there are a few breaks with keypads.
Andy.
x 94
Re: Xantia TU ?
Unread post by citronut »
Andy are you sure it was a 1.4 TU and not a 1.6 TU as in the Saxo VTR and the 1.6 VTS twin cam version
Regards, malcolm.
x 94
Re: Xantia TU ?
i just looked on pug service box and here is a list of all engines in MK1 406's
i cant see any TU engines in either list
Title Application Supplier
ENGINE DIESEL TURBO XUD9SD
DW10ATED TURBO DIESEL
INJECTION ES9J4
INJECTION XU10J4R
INJECTION XU5JP
INJECTION XU7JB
INJECTION XU7JP
INJECTION XU7JP4 AND LPG + UNLEADED PETROL SINCE RPO 07665
INJECTION XU7JP4 AND LPG + UNLEADED PETROL UNTIL RPO 07664
INJECTION XU7JP4 SINCE RPO 07665
INJECTION XU7JP4 UNTIL RPO 07664
TURBO DIESEL XUD11BTE
TURBO DIESEL XUD9TE AND EEC 19-5 DEPOLL (ENGINE)
TURBO DIESEL XUD9TE AND EEC 95 DEPOLL (ENGINE)
TURBO INJECTION XU10J2TE
ENGINE COVER DW10ATED TURBO DIESEL
FIXING POWER UNIT DW10ATED TURBO DIESEL
INJECTION ES9J4 AND BVA SINCE RPO 07967
INJECTION ES9J4 AND BVA UNTIL RPO 07966
INJECTION ES9J4 AND BVM5 SINCE RPO 07967
INJECTION ES9J4 AND BVM5 UNTIL RPO 07966
INJECTION XU10J4R AND Auto gearbox AL4 SINCE RPO 07784 UNTIL RPO 07966
INJECTION XU10J4R AND Auto gearbox AL4 SINCE RPO 07967
INJECTION XU10J4R AND BVM SINCE RPO 07967
INJECTION XU10J4R AND BVM UNTIL RPO 07966
INJECTION XU10J4R AND HP20 (AG) UNTIL RPO 07783
INJECTION XU7JB SINCE RPO 07967
INJECTION XU7JB UNTIL RPO 07966
INJECTION XU7JP SINCE RPO 07967 OR INJECTION XU5JP SINCE RPO 07967
INJECTION XU7JP UNTIL RPO 07966 OR INJECTION XU5JP UNTIL RPO 07966
INJECTION XU7JP4 AND BVA SINCE RPO 07967
INJECTION XU7JP4 AND BVA UNTIL RPO 07966
INJECTION XU7JP4 AND BVM SINCE RPO 07967
INJECTION XU7JP4 AND BVM UNTIL RPO 07966
INJECTION XU7JP4 AND LPG + UNLEADED PETROL SINCE RPO 07967
INJECTION XU7JP4 AND LPG + UNLEADED PETROL UNTIL RPO 07966
TURBO DIESEL XUD11BTE SINCE RPO 07967
TURBO DIESEL XUD11BTE UNTIL RPO 07966
TURBO DIESEL XUD9TE SINCE RPO 07967 OR DIESEL TURBO XUD9SD SINCE RPO 07967
TURBO DIESEL XUD9TE UNTIL RPO 07966 OR DIESEL TURBO XUD9SD UNTIL RPO 07966
TURBO INJECTION XU10J2TE SINCE RPO 07967
TURBO INJECTION XU10J2TE UNTIL RPO 07966Title Application Supplier
INJECTION ES9J4
INJECTION XU10J4R
INJECTION XU5JP
INJECTION XU7JB
INJECTION XU7JP
and here is all MK2
ENGINE DW10ATED TURBO DIESEL OR DW10ATED TURBO DIESEL PARTICLE FILTER
DW12TED4 TURBO DIESEL
INJECTION ES9J4
INJECTION ES9J4S
INJECTION EW10J4 OR EW10D INJECTION OR INJECTION EW12J4
INJECTION EW7J4
INJECTION XU10J4R
INJECTION XU5JP
INJECTION XU7JB
INJECTION XU7JP
INJECTION XU7JP4 AND EEC 2000 DEPOLL (ENGINE)
INJECTION XU7JP4 AND EEC 95 DEPOLL (ENGINE)
TURBO DIESEL DW10TD
ENGINE COVER DW10ATED TURBO DIESEL PARTICLE FILTER OR DW10ATED TURBO DIESEL
EW10D INJECTION
INJECTION EW12J4 OR INJECTION EW10J4
INJECTION EW7J4
TURBO DIESEL DW10TD AND MOUNTING BOSCH UNTIL RPO 09106
TURBO DIESEL DW10TD AND SIEMENS ASSEMBLY SINCE RPO 09065
FIXING POWER UNIT DW10ATED TURBO DIESEL OR DW10ATED TURBO DIESEL PARTICLE FILTER
EW10D INJECTION
INJECTION ES9J4S AND BVA
INJECTION ES9J4S AND BVM5
INJECTION EW10J4 AND Auto gearbox AL4
INJECTION EW10J4 AND BVM
INJECTION EW12J4
INJECTION EW7J4 AND LPG + UNLEADED PETROL
INJECTION EW7J4 EXCEPT LPG + UNLEADED PETROL
INJECTION XU10J4R AND BVA
INJECTION XU5JP
INJECTION XU7JB
INJECTION XU7JP
TURBO DIESEL DW10TD
Regards, malcolm.
spider
x 77
Re: Xantia TU ?
405 Malcolm, not 406 :)
I don't think they were UK specification though, not sure if that helps. I do see some listed on my tech data both for 405F and 405N now I've looked. I've not checked ServiceBox yet. I've only seen a couple at the newer shape (405N) though.
Talking of 406's I saw one 406 with a DW8 in it (Spanish Reg) although I could never find any detail on it, sort of suspected it was something the owner did. It came in for brake pads and maybe a tyre nothing more if I remember correctly.
Andy.
x 94
Re: Xantia TU ?
whoooops didnt read it properly and yep you are right
heres the list of 405 SAUF RESTYL
ENGINE CARBURETTOR AND TU3 AND TU3A
CARBURETTOR AND TU3F2
CARBURETTOR AND XU
DIESEL AND XUD7 AND ASSEMBLY ROTO DIESEL AND CAM DRIVENVACUUM PUMP
DIESEL AND XUD7 AND ASSEMBLY ROTO DIESEL EXCEPT CAM DRIVENVACUUM PUMP
DIESEL AND XUD7TE AND CAM DRIVENVACUUM PUMP EXCEPT AIR CONDITIONING
DIESEL AND XUD7TE EXCEPT CAM DRIVENVACUUM PUMP
DIESEL AND XUD9 AND ANTIPOL EGR AND CAM DRIVENVACUUM PUMP BOSCH
DIESEL AND XUD9 AND ANTIPOL EGR EXCEPT CAM DRIVENVACUUM PUMP BOSCH
DIESEL AND XUD9A AND CAM DRIVENVACUUM PUMP
DIESEL AND XUD9A EXCEPT CAM DRIVENVACUUM PUMP
INJECTION AND XU
FIXING-POWER UNIT LIFT POINT CARBURETTOR AND TU3 AND TU3A
DIESEL AND XU
INJECTION AND XU9J4
PETROL AND XU EXCEPT XU9J4
and here's MK1's
ENGINE CARBURACION XU
CARBURETTOR TU3-2
DIESEL XUD9 AND EEC 19-5 DEPOLL (ENGINE)
DIESEL XUD9 AND EEC 95 DEPOLL (ENGINE) BOSCH
DIESEL XUD9 AND US 87 DEPOLL (ENGINE) UNTIL DATE 19940601 BOSCH
INJECTION TU3MC
INJECTION XU10J4 OR TURBO INJECTION XU10J4TE OR INJECTION XU10J2
INJECTION XU5M OR INJECTION XU5JP OR INJECTION XU7JP4 OR INJECTION XU7JP OR INJECTION XU9J2
TU5JP4 INJECTION
TURBO DIESEL XUD9TE
FIXING POWER UNIT CARBURETTOR XU92C AND BVA OR CARBURETTOR XU52C AND BVA
CARBURETTOR XU92C AND BVM OR CARBURETTOR XU52C AND BVM
DIESEL XUD9
INJECTION TU3MC OR CARBURETTOR TU3-2
INJECTION XU10J2 AND BVA
INJECTION XU10J2 AND BVM5 4X2
INJECTION XU10J2 AND BVM5 4X4
INJECTION XU10J4 AND BVM
INJECTION XU7JP4
INJECTION XU9J2 AND BVA OR INJECTION XU7JP AND BVA OR INJECTION XU5JP AND BVA OR INJECTION XU5M AND
INJECTION XU9J2 AND BVM OR INJECTION XU7JP AND BVM OR INJECTION XU5JP AND BVM OR INJECTION XU5M AND
TU5JP4 INJECTION
TURBO DIESEL XUD9TE
Regards, malcolm.
spider
x 77
Re: Xantia TU ?
Yes, a rare-ish one to say the least. :)
They also list a 306 carb (TU3) although I've never ever ever seen one. I'd assume its non-UK markets only as given the first 306's I saw were K plate ( you can tell very early ones as they had the 205/309 pedal box ;) ) were too late to be carb'ed given our emission regs at that time. Same I think as only J plate 106's had carb's. I used to wonder where the choke cable lived on these as I could not see any suitable orifice in the dash for them although they state manual choke (thankfully!)
Then again, early build unregistered for a while... :-k
Andy.
KP
x 27
Re: Xantia TU ?
Unread post by KP »
The 1.6 TU without PAS was certainly imported into the UK...
I have seen and shortly driven such an example, and the lack of PAS isnt as bad as you think! its a lot lighter than a Xantia with failed hydro circuit but by far from light :D
