206 hdi anti pollution fault
delo2013
New User
Unread post by delo2013 »
Thanks h2ocooler
For diagnostics on my 206 2.0 hdi 2002
with anti pollution fault and engine management light on
Po571
P0221
Codes we came up with
Any advise on what I need to replace or look into with the above codes please so I can get through my mot in june as em light now a failure ?
h2ocooler
Re: 206 hdi anti pollution fault
Unread post by h2ocooler »
Now worries del.
Bit more info for people to help you with.
1st fault was permenant, brake light switch open circuit.
2nd fault was throttle discrepency, 40% sensor 1 & 52% sensor 2.
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
x 1056
Unread post by wheeler »
The first thing to do is check the brake lights are working correctly, very common on 206's & picasso's, usually the lights stick on making the ECU think you are braking & accelerating at the same time, often acompanied by a loss of power aswell.
delo2013
New User
FIXED. :)
Replaced brake sensor and replaced throttle sensor H20cooler reset my fault codes and no anti pollution fault anymore. Emlight no longer on.
Brake sensor was noticeably burnt out inside, throttle sensor requires special tool to access internallly so £20 one from breakers seems to work fine.
Many thanks h20cooler
h2ocooler
You are welcome Del, glad to be able to help.
