Which Gasket ?
Timmy69
Which Gasket ?
Unread post by Timmy69 »
Hi
I mentioned an oil leak on my new car C5.Well it turns out to be the rocker cover gasket,which is not a hard job even by my standards:p .Anyway the problem i am having is which one i need because their are two.One for inlet and the other for exhaust.I am assuming that i need the inlet one but thought i would make 100% sure before i bought one.I need the one that has the oil filler cap.
Thanks in advance
Timmy
x 1479
Re: Which Gasket ?
Which engine?
Timmy69
Re: Which Gasket ?
RichardW wrote:Which engine?
Its the 1.8 petrol engine...does that make a difference ?
x 94
Re: Which Gasket ?
Unread post by citronut »
if you send me the last 8 digits of your chassis/VIN No. i will get the OE part No.' and price from service citroen
Regards, malcolm.
x 1479
Re: Which Gasket ?
1.8 and 2.0 petrol appear to use the same gasket:
19
0249 A4
01 GASKET ROCKER COVER
ADM
- INJECTION EW7J4
Only £7 from Citroen
