I have just changed the axle on my 1993 zx volcane td for one from a 1.9i volcane as the trailing arm bearings were stuffed. The problem is that after fitting it I now realise that the calipers dont fit, as mine was abs equipped and the new axle is not. The caliper bolts seem to be too big for the mounts on the hub. Then I relaised that the whole hub assembly looked different. I had originally thought that these parts were all interchangeable, but it seems more coplex that i first thought. [:I]
Firstly, is there any way to change the caliper (and abs sensor) mounting bracket without first removing the hub and wheel bearing?
Also, if I do have to remove the wheel bearings, do I have to use a proper puller or can I just be a bit rough as I dont need the bearings again?
Cheers[:D]
Zx Axle (wheel bearings)
Jon
mrbump
OK, so I need to change everything over form my old ABS axle, but can it be done without buying new bearings (hubs)? What are the chances of removing both of the old hub and bearing units and re-installing them without knackering the bearings? I have read elsewhere (here and haynes) that it is almost impossible? Has anyone ever had success with this?
cheers
cheers
