xantia lhm leak
AllenR
xantia lhm leak
Unread post by AllenR »
I have fluid leaking out of the hose which is to the right side of the sphere at the front of the engine The hose has a white line runnig along is length up to the main resovoir,also has green/yellow band around it. Does anybody know if hydraulic crimps at hose ends are remakeable or is it a new part
Dave Burns
x 3
Unread post by Dave Burns »
Does this pipe come from the bottom of the regulator, if so this is the return from the pump to the reservoir and is low pressure, a jubilee clip can be used on this pipe, the pipe you described in your earlier post on this subject is at high pressure and will resist any attempt at a diy repair.
Good luck
Dave
