After a slight error of judgement I find myself having the replace the front offside wing on my wife's 2003 C5 2.0HDi sx hatchback - Can anybody tell me if the hatchback and estate front wings are interchangeable - I get the impression from my searches on ebay that they are not, but I don't want to exclude possible sources.
Richard
C5 Front wing
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Re: C5 Front wing
Part numbers for saloon and estate are both the same.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- (Donor 2017)
- My Cars: Citroen C5 2.0 Hdi 2003
- x 39
Re: C5 Front wing
They are interchangeable. You don't mention how bad the damage is as they are a bit of a pain in the ass to change.
I'v found it a bit tricky removing the old panel (seam sealer) and then lining up the panel gaps properly on the new one takes a bit of care.
For a minor dent you might consider a paintless dent removal chap, as it may work out a lot easier and not too expensive,
Sam
Sam
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Re: C5 Front wing
no reason for them to differ Richard,
also it is usually cheaper to find a good second hand wing in the same colour,
try this company as the last time i visited them they had some MK1 C5's in
G.M Woodgate & Son
01233 850303
Potteries Further Quarter
High Halden
Ashford
Kent
TN26 3HX
they must be one of very few old fashioned breakers left, were your allowed to climb over the cars and take bits off yourself
G.M Woodgate & Son
01233 850303
High Halden
Ashford
Kent
TN26 3HX
Regards, malcolm.
Re: C5 Front wing
Many thanks - unfortunately although the damage is localized to the wing it is not minor so I think changing it will be simpler, even if it is a PITA. I will be looking for one in the same color. I've used Woodgate's in the past for xantia parts and got on well with them so I'll go and have a look.
Regards
Richard
Regards
Richard
Re: C5 Front wing
i'd give them a call first as its a while since i went there
Regards, malcolm.
