Still got Xantia water leak woes :(
mirafioriman
Unread post by mirafioriman »
Well, despite checking and sealing lots of things I still seem to have a bad water leak into the rear of my early Xantia hatch. It seems to be appearing in the right rear corner of the boot and running forward into the rear seat area.
The rear interior and carpets including the boot carpets are all stripped out. I went out tonight and poured water from a watering can into the rear hatch channel area and around the rear lights with the tailgate open and there was no sign of any leaks.
I've had the headlining out and checked the sunroof drains are all clear and flowing twice now and all seems fine however something is nagging at me that it is indeed the sunroof.
Unless someone can suggest any other possible sources of water ingress I'm going to tape up the sunroof with ducktape and a heavy duty bin liner to erradicate any possibility of it letting water in and see what happens.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Xaccers
x 186
Re: Still got Xantia water leak woes :(
Unread post by Xaccers »
Have you checked the roof bar screw holes above each door are still covered in their factory latex?
Peel back the door/roof seal to check them.
DIY sphere tool
mirafioriman
Thanks for the reply. Someone else mentioned this a while back and I sealed them with tigerseal.
Xantidote
x 5
Unread post by Xantidote »
As the watering can didn't help trace the leak, you'll have to resort to the hose pipe.
Martin
1995 Xantia TDLX (deceased :( )
