Was sat at petrol station waiting rev up and pulled up to pump and a message popped up on mult display saying overdrive off?
Mind i do keep catching the stalks as well with my knees.
Car runs fine but what is over drive?
What does overdrive mean?
ej2095
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
spider
- x 77
Re: What does overdrive mean?
What vehicle ?
I guess its not being used in its 60's / 70's terminology anymore though ie legacy 3.5 4.5 gears, I was going to say 5th but it tended to work in more than one ratio.
Auto ? , Some autobox's count 4th (or 5th) as 'overdrive' , ie only use the first three / four ratios.
Andy.
411514
- (Donor 2017)
- x 40
Was it a C5, if so was it overspeed, which is just an adjustable warning that you can set when the car exceeds a certain speed.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Chlorate
Generally speaking, overdrive is when the output shaft of the gearbox is moving faster than the engine.
Often in a 5 speed gearbox 4th is 1:1 and 5th is slightly overdrive.
Back in the day, cars would have a separate overdrive gearbox to add a little more high gear i.e. the 3.5 & 4.5 gears Spider mentioned. And this could be engaged/disengaged at will.
I have no idea if anyone is still fitting them to cars
What car is it?
What car is it?
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
isisalar
- x 3
'Back in the day' one of the most interesting old cars I owned was a Triumph vitesse. It had a 1600cc 6Cyl engine, twin SU's, and overdrive on third and fourth. Very smooth and fantastic torque.
Who said 6 speed speed gearboxs were a new thing?
From memory I think it was a1965.
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
handyman
Yes, but the real trick was to drop in the 2.5 PI engine with overdrive, and modify the selection plate so you got overdrive in 2nd as well!
I did a few of these conversions for Vitesse and GT6 owners who were more than happy with the transformation.
My own 2.5PI was so modified and also fitted with a 357 cam and an LSD. Could easily see off any F*rd Capri at the traffic lights drag!
Gave it a seven speed gearbox with no wheelspin, only traction.
H
H
ej2095
yes c5 hdi 2.2
ej2095
and could have been over speed lol
lexi
- x 134
Hey Handyman, I had a big 2.5 pi with the Laycock O/D. 5yrs I had it. That trick of sitting behind a car in o/d third and then hit the switch to drop to third, was brill. They were special at the time.
We are still using bolt on overdrives with old Land Rovers. They are Fairey and pretty whiney things.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
JohnD
- x 72
In the late '70s I bought a Transit to convert into a motor caravan. It was fitted with Ford's 2.4 York diesel engine. I heard of a guy in Essex who converted Transit gearboxes into overdrive boxes my grafting on the overdrive from Zodiac cars. I decided to have mine done. What a transformation. By the flick of a switch, speed was maintained but revs dropped right down. Overdrive worked on 2nd, 3rd & 4th, so really you ended up with a 7 speed van.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Old-Guy
- x 24
TR2 and later a Triumph 2000 estate both with overdrives.
Then flick the switch back into overdrive as you go past - with 3 kids and a black lab in the back!lexi wrote:Hey Handyman, I had a big 2.5 pi with the Laycock O/D. 5yrs I had it. That trick of sitting behind a car in o/d third and then hit the switch to drop to third, was brill.
