Wheel alignment - anything I should know about?
evoke
Unread post by evoke »
One of the last things on my to-do list for my C5 MKIII is to get a wheel alignment done. Am I correct in assuming that this will be straightforward or is there anything I should be aware of?
I've generally had a full wheel alignment done on every car i've ever owned, even brand new ones driven out of the showroom! More often than not, i've been able to tell the difference in handling straight away.
2008 Citroen C5 2.2 HDi Exclusive
x 1240
Re: Wheel alignment - anything I should know about?
Unread post by Peter.N. »
Should be a straightforward job, I do mine myself with a very cheap home made tool consisting of a length of threaded rod and metal conduit tube. There is no rear adjustment as it has radius arms - unless yours has springs.
