no aircon after battery renewal
KGMASLEN
Hi, after renewing my C5's battery, which was 10yrs old, the venting and aircon ceased to work properly. Any suggestions?
Ben82
- x 7
Re: no aircon after battery renewal
I'm guessing a proper BSI reset process wasn't followed... take a look at this thread. I had a random no-start condition where all the electronics would die (ranging from after a few minutes to 3 weeks between occurrences), and would mean I would need to disconnect and reconnect the battery to get the car to play ball.
It's now coming on to 4 weeks since I did a BSI reset and have not had the issue since, so well worth a shot as others have reported the same process has cured issues after an incorrect battery change
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
KGMASLEN
Hi Ben, thanks for info will try and will report back as to the outcome. Regards K.
KGMASLEN
Hi Ben me again! The thread you suggested sadly did not work in my case. Now having to resort to an aircon specialist
. Thanks for your help, only wish it had done the trick. Regards Ken M.
