Hello,
I have decided to update the Firmware of my Sat/Nav.
My car is a 2001, C5 Exclusive SE V6.
This is how I failed to manage the task:
1) I started the engine.
2) I removed my Map Disc.
3) I inserted my, (Official, and I assume correct, it came with the car), Firmware Disc.
4) A message on the Main Display, (I have the large colour screen), showed me details re' Firmware and CD. It also asked if I wanted to Install.
5) I chose Yes.
6) A message was displayed, which was along these lines, "Please be patient. Installing is taking place".
7) I then waited, patiently, for approx' 20 minutes. However, nothing further occurred.
8) I switched of the Ignition.
9) I restarted the engine.
10) Once again the message was displayed, asking if I wanted to Install.
11) This time I answered No. I was then asked to eject the Firmware Disc.
12) I then reinserted my Map Disc.
13) My Sat/Nav then functioned as normal. However, no update had occurred.
Sorry about the long winded list above.
Has anyone successfully managed to Update their Sat/Nav Firmware?
If so, how did you do it?
Many thanks for any assistance.
Paul
C5 Sat/Nav Firmware Update
qprdude
- x 14
Re: C5 Sat/Nav Firmware Update
Not on your age of car, but you will need to keep the engine running to avoid going into economy mode because the install will stop. I updated my firmware and maps and it took over 20 minutes. I have a hard disc type nav, so no disc in the drive, although it is installed from CD,s initially. Not sure how your system works.
Rick.
2013 Citroen DS 5 D/Sport
- x 3566
I'm not familiar with the early C5 update procedures, but.......Dircon wrote:1) I started the engine.
When you say... "inserted my, (Official,....etc, etc), do you actually mean a disc that's physically been with the car since new - 2001 ? If so, it might be that this disc has the same firmware on it as is already installed so it might not update it as it thinks it's already up to date.
