Faulty brake fluid warning 406
paul_c
Unread post by paul_c »
I always bat a low brake fluid warning when I pull on my hand-brake. The brake fluid level is fine. I understand this is a known fault caused by a faulty sensor on the handbrake. Anybody know where the sensor resides and hoe easy it is to replace?
Cheers
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Check that the handbrake and low fluid indicator don't use the same warning light.
assael1
Unread post by assael1 »
Hi
it's common problem on 406 . have to replace the handbrake switch, new shape.
ITSIK
