I need to top up the power steering fluid in the 407 and the recommendation is Total Fluide DA which seems elusive. It is an orange coloured oil and seems to be exactly the same as LDS, even sharing the same PSA specification. Are they in fact the same?
Does anyone who knows better think that it would be suitable and if not can they recommend a suitable alternative.
Total Fluide DA & LDS
Toby_HDi
- x 3
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
TooMany2cvs
Re: Total Fluide DA & LDS
Ignore the label on the bottle - they might prefere Total, but they can't insist you use Total. What they can insist you use is a fluid that meets the PSA S71 2710 spec. And - oh, look - LDS meets the spec... <grin>Toby_HDi wrote:I need to top up the power steering fluid in the 407 and the recommendation is Total Fluide DA which seems elusive. It is an orange coloured oil and seems to be exactly the same as LDS, even sharing the same PSA specification. Are they in fact the same?
Same viscosity, same spec listed on the original Total data sheets...
DA - http://www.lubadmin.com/upload/produit/ ... 1/4002.pdf" onclick="window.open(this.href);return false;
LDS - http://www.lubadmin.com/upload/produit/ ... 3/4003.pdf" onclick="window.open(this.href);return false;
More confuzzlingly, though - this meets the same spec, but is coloured green.
http://www.opieoils.co.uk/p-60197-fuchs ... fluid.aspx" onclick="window.open(this.href);return false;
Adrian
toomany2cvs (a) gmail.com
A miscellany of motorised silliness, from 0.75bhp to 9ft tall.
http://www.WhereverTheRoadGoes.com" onclick="window.open(this.href);return false;
xantiasmiff
I purchased Total Fluide DA at my local Peugeot dealer. I looked in numerous local motor factors and Halfrauds first but no joy. Seems to be dealer only.
lambchopper321
Cheers guys , looks like lds it is then. , I'm hoping one of the trade supply places is open in the morning as most of them seem to have it
cancunia
A fairly old thread, but seems to be a similar question to mine.
I need to replace the steering fluid on my '05 Berlingo again as the ECP Dexron III that I used seems to have lost it's strength. I replaced some of it this morning, with some more from the same bottle and the steering is noticeably better, so I'm guessing the ECP stuff is not really up to the job.
I thought about using some fully synthetic, and then came across the Fluide DA mention in the official Citroen documents.
Anyone any thoughts about the best steering fluid for a Berlingo M59?
