Is is normal to have this noise and play in driveshaft ?
daviepaisley86
Unread post by daviepaisley86 »
Got a creaking noise happening when moving off and when braking so thought id have a look under the car and noticed that there is noise while pushing down on the suspension hard and fast that looks as if it is coming from the lower control arm but took the wheel off anyway for a closer look and noticed play in the driveshaft while rocking back and forth.
Heres a video so you know what Im talking about :)
[youtube]http://http://www.youtube.com/watch?v=_GiF0UwXHSU[/youtube]
Peugeot 206 2.0 HDI 90
x 94
Re: Is is normal to have this noise and play in driveshaft ?
Unread post by citronut »
you video link does not work
Regards, malcolm.
daviepaisley86
Fixed the link :)
x 94
daviepaisley86 wrote:Fixed the link :)
still dont work :shock: #-o :wink:
Regards, malcolm.
Ben82
x 7
Unread post by Ben82 »
here:
daviepaisley86: just need the video ID between the tags :)
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
x 94
thats better
and no it aint meant to do that, are you sure its the diff and not the drive shaft triack/inner joint
Regards, malcolm.
