Spare wheel - is it supposed to be secured?
evoke
Unread post by evoke »
Does anyone know if the spare wheel in the boot in a Citroen C5 MKIII is supposed to be secured in any way? Mine is unsecured with the tool kit in the centre. On other cars i've had the spare wheel had a long bolt through the centre, securing it to the floor of the boot.
2008 Citroen C5 2.2 HDi Exclusive
qprdude
x 14
Re: Spare wheel - is it supposed to be secured?
Unread post by qprdude »
The spare is secured by a strap across it. No threaded retainer. My wheel is very tight in the wheel well. Not sure if it is because it is a 19 inch wheel or not. I tend to fill any space round the wheel with rags, high via vests etc, once it is strapped in. Makes for good fit, and stops any rattles.
Rick.
2013 Citroen DS 5 D/Sport
evoke
^ Thanks. I'll check the wheel well properly later today. I haven't had a good look since I got the car in February but I know there was no strap across it.
evoke
Found the straps! They were underneath the spare wheel. Also pumped up the spare wheel as it was at 24PSI.
Old-Guy
x 24
Unread post by Old-Guy »
I'd keep a close eye on that spare: it might have been unsecured because it had recently been swapped or repaired when you bought the car. Now it might have a slow puncture in it.
evoke
^ Good advice. Will do. I'll check the tyre pressure again after a week or so.
