Xantia engine pulley change
charentejohn
Unread post by charentejohn »
Just about to do this (raining today) and have a quick question, I assume the bolt is right hand thread ?
Just checking before using an air impact wrench. Should be right hand thread as the pulley has a woodruff key so shouldn't turn anyway, still you never know, wouldn't be the first time I have tried to remove a bolt the wrong way, usually resulting in snapping them.
Fitting one of the new pulleys from Corteco which have a solid looking rubber face, without the slots.
I wasn't sure it was right and rang them, they told me these are better / safer as they are concentric rubber rings rather than rubber discs. We shall see.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
x 1496
Re: Xantia engine pulley change
Yes, RH thread. Put it in 4th gear and apply the handbrake hard, should be enough to hold it if you are using an impact gun. 22mm socket required....
charentejohn
Thanks, will do that. Always best to check, following the 6P rule, Proper Planning Prevents P Poor Performance. :-D
charentejohn
Just another question on this, I had to give up as I couldn't release the lower adjuster so didn't want to fit a new belt and not be able to adjust it.
This is the lower adjuster not the spring loaded top one (Xantia HDI 90).
Question is how hard should I have to turn to release it and will an air powered impact driver help ?
The adjuster uses a hex key, not a square one as most seem to be, so my plan was to use a hex bar I have that fits it then use ai impact driver on that.
I have only used an impact driver (air powered) a couple of times, would this be a better way to remove the adjuster as it should 'ease it out' rather than seeing the twisting of the allen key as at present.
Breaking this would be a real pain.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Are you talking the Aux Belt, eccentric pully?? They are an 8mm ALLEN head bolt...
The upper spring loaded tensioner uses a LEFT handed thread on the bolt. Remove the ECU box (two 10mm bolts are removing the ECU out the box) you can get at it easyer.. Use a 15mm YES 15mm spanner on the bolt head to left the tension and release the belt...
The eccentric again is RH thread. ONLY the upper spring tenionser is a LH thread for obvious reasons..
A very sad...
1994 XM 2.1 d auto
charentejohn
Sorry for posting this then wandering off, but back now.
Yes it is the eccentric pulley, at the bottom of the engine. Good to know which way to turn it :)
I am a bit of a wimp when it comes to putting massive pressure on bolts etc, I have sheared too many with dire / expensive consequences.
I was hoping using an air impact wrench would loosen it with a lower risk of shearing.
I really want to do stuff myself, but if there is a risk of shearing the bolt I would rather it was in a garage where they could fix it. Replacing the crank pulley ant timing belt should be a simple procedure, just this tensioner pulley that is worrying me.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
If my rattle guns dont crack it then I am giving the starter motor trick a go.
