Fitted new clutch the weekend and know clutch pedal is rock solid, I tied it up whilst changing clutch I removed slave to see and clutch pedal is still rock solid however I can push slave back in itself so presume maybe I have tied pedal too high and its past a return point maybe it does it need bleeding I can see nipple on slave but can't find master cylinder to top up other end.
Please help.
c5 hdi clutch problems
russ hdi
CITROEN C5 2.0 HDI SX 2003
Currently rebuilding grand espace 2.2 rxe full leather 3 sunroofs
- x 2941
Re: c5 hdi clutch problems
If the pedal's rock solid it's unlikely to be a 'bleeding' problem, more likely that there's a mechanical problem in the pedal or associated parts.
