Easy hard front suspension fix (Hydractive)
rory_perrett
Unread post by rory_perrett »
Sorry this isn’t going to help those guys suffering hard front suspension on non hydractive Xantias.
Car went very bouncy on the front end earlier this week. Unlike last time when it was an ecu failure the back stayed soft.
Lexia confirmed that the ecu was switching both front and back to soft.
Both front corners were hard so thinking it could be a failed valve or a ruptured centre sphere. Then I had a thought, pulled the multiplug off the ecu, gave it a quick squirt of contact cleaner and replaced.
Suspension back in working order. :)
Now we like those sort of fixes don't we! :lol:
x 8343
Re: Easy hard front suspension fix (Hydractive)
Don't you just love nice easy ones like that Rory :-D
They so rarely happen to me. I always get the complicated ones :twisted:
Have you done the Hydractive diode mod?
Mandrake
x 695
Unread post by Mandrake »
Fingers crossed that you've found it, but I have a suspicion that that squirt of contact cleaner won't be the last you'll see of that problem rory. :(
If there is enough of a fault with the wiring (high resistance) to prevent the electrovalve energising properly the ECU should (usually does) pick up the lack of current and goes into a failsafe mode where it switches both electrovalves into hard mode.
This will cause the rear of the car to also go hard. The fact that the rear didn't go hard and the Lexia didn't report a fault suggests that you might have an intermittent version of the faulty diode issue, as a faulty back EMF diode usually isn't detected by the ECU.
The front electrovalve on my previous Xantia had a dry joint on the diode within the moulded coil packaging that was causing the connection to the diode to go high resistance when the engine bay heated up. This was causing the electrovalve to intermittently fail to operate while driving when the car was hot but it usually passed the bounce test when stationary! It took me a long time to pin this intermittent fault down and prove it conclusively.
If you haven't done it, definitely do the diode mod, if only for insurance and peace of mind...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
rory_perrett
Thanks guys - yes I know its probably not the end of it, but I'll take the fix for now.
I have done the diode mod, did it in my previous Xantia when the ones on the car seemed to have failed. Did this one straight away when I got it as I had some diodes left over.
taffy
Unread post by taffy »
What's this diode mod and where is The hydro ecu?
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
