Hi all
I have an ODB blue reader flaoting around at home but doesnt work on C5 mk1
So what cables do i need to read the onbaord ecu? also software please?
OBD port
Re: OBD port
A C5 mk1 most likely can't be read by any standard OBD-II reader as it's not OBD-II compliant despite the same type of socket being used.
You'll need a Lexia to read it. These days a Lexia is just a special interface, cable and software for a Windows laptop. Check the Lexia / Diagbox sticky threads or one of the many other threads floating around the forum about the Lexia for more information. A Lexia would let you do more or less anything that a dealer could as its the same tool used by dealers.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Re: OBD port
Ebay job then for the cable ?
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
- Ben82
- My Cars: C5 V6 2004
- x 7
Re: OBD port
All C5 Petrol engines should be OBDII compliant as EU regs required them to be from 2001, and diesels from 2004. Apparently you can check on service.citroen.com to see whether it is complaint.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Re: OBD port
My 1999 hdi 2.0 hdi has a bluetooth obd reader off ebay and I use apps on my phone to read The data such as torque etc..worth a try for a tenner
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
