i have 70mA-90mA (0.07 - 0.09 with multimeter on 10a range) power drain with parked and locked car. I have tried disconnecting fuses one by one [well all fuses except the huge 40 and 60 amp ones in engine bay] to check out what is causing it, but it never went down, only went UP when disconnecting one fuse.
I'm measuring drain on battery - i disconnected + wire and connected multiplier between + pole on battery and clamp on + wire.
My owner manual does have fuses marked wrong so i was not able to identify which one it was.
BTW is there any way to get drivers door opened and car to think it is locked? It would make these experiments more comfortable.
Also i have calculated then one bulb on in the trunk would take about 0,4A (i'm guessing bulbs are 5w), but even when i open doors and all the bulbs goes ON multimeter just shows 1,1A. So what is drain of one interior/ glovebox/ trunk bulb?
