An exciting ebay buy
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
No toolbox should be without one:-
http://www.ebay.co.uk/itm/Electric-hamm ... 7196095%26" onclick="window.open(this.href);return false;
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
qprdude
x 14
Re: An exciting ebay buy
Unread post by qprdude »
What a great find! :clap:
That looks like the electric claw hammer which is more for woodworking. I have the ball peen one but the safety certificate has expired and the leather holster has developed a slight touch of mildew.
I had a matching pair of hens legs, but they seem to have run off. :-**
Rick.
2013 Citroen DS 5 D/Sport
handyman
Unread post by handyman »
Coo! Its just like Ebay used to be before they got all serious and up themselves. :shock:
I had one of these electric hammers, got burnt in the fire, now I've only got the head but I'm still looking for the rest of it. #-o If memory serves, although this is the claw version, primarily to be used in carpentry, it can, at a pinch, be used to hit most things. :shock: :domo:
I did have a tin of elbow grease, a sky hook and a skirting ladder, but Gawd knows where they are now. #-o
H
x 94
Unread post by citronut »
i hope its got the correct size fuse and the plug is wired correctly ( ELF AND SAFTEY and all that )
Regards, malcolm.
x 5683
citronut wrote:i hope its got the correct size fuse and the plug is wired correctly ( ELF AND SAFTEY and all that )
Vendor says it has been PAT checked but predates elf and safety laws.
(did you read the Q&A) :)
x 94
myglaren wrote:Vendor says it has been PAT checked but predates elf and safety laws.
a Pat wont test it properly it needs a really good whack to make sure its realy doing its stuff,
no Steve
i havent read the Q&A's yet
Regards, malcolm.
qprdude
x 14
It should probably be given a drop test.
Even if manufactured after the health and safety requirement, the handle should be certified as fire resistant.
Rick.
handyman
Yea, but has it got a CE certificate to show its EU compliant so it can be used in foreign parts? Or was that on? That plug top is definitely not to BS 1363! :shock:
x 8448
myglaren wrote: Vendor says it has been PAT checked
Pat must be a busy bloke. he seems to test and check an awful lot of stuff...
