Hello,
I noticed that I lost the bolt that connects the airbox to the engine body, the one in the center that has a rubber ring.
The rubber ring is still there but the bolt is gone.
Could it cause problems (do i need to replace it)?
thanks
207 lost bolt
Lighty
- x 34
Re: 207 lost bolt
Shouldn't cause any problem, will most likely have fell down past the gearbox and be on the floor or the under tray. You ought to put a new one in, as it's only now held on bythe jubilee clip to the throttle body
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
assasukasse
Re: 207 lost bolt
yeah, very likely is sitting in some motorway...
Where should I get another one? Should I just put an M5 screw?
