After getting the electrics to fuse box renewed and £230 lighter, when car came back has now got ABS light on dash on all the time...
Any ideas guys ???????
ABS Light
JohnD
- x 72
jeremy
- x 3
John - I don't agree with you. If the ABS light stays on it is an indication of a fault that can be detected while the car is stationary, if it comes on when the car is moving it is an indication of a fault that can be detected when the car is moving - ie a poor output from a sensor, intermittent fault, wrongly positioned sensor etc.
When the light fails to go out it is usually an indication that one or more sensors has failed and when the ECU does its continuity check one fails.
I don't know how a Xantia ia wired but on a BX the sensor leads join the leads to the ECU in a plug on or near the bulkhead on each side. I expect a Xantia is similar and I expect one of these connectors has been parted during the work. I suggest you try and trace the wire from each hub and see where it goes and if you can find the connectors.
There are loads of postings here on the subject of testing sensors etc on here.
jeremy
jeremy
BigMac
Hugo
If the problem has appeared AFTER the work was done, then I suspect your mechanic needs to correct his work. This sort of thing happends all the time, as we're only human. A reasonable garage will take it back and have a good look to see if anything has been forgotten.
Other than that, just double check that the ECU has been reconnected. He may have disconnected it whilst checking the loom, as they are fregile at times (as I know only too well!) It is situated above the battery under a plasic cover. The connection is via a multi pin connector that uses a clamping arrangement.
It may be a good idea to disconnect the battery when you remake the connection.
All the best!
Hugo
All the best!
Hugo
