My steering rack started leaking from the pinion seal losing all the fluid.
There are two offered by the local motor factors. One, 2.75 turns lock to lock, the other 3.25 lock to lock. Mine is 3.0 turns lock to lock. No one seems to know what to supply, can anyone here help?
Thanks, Peter
'02 C5 steering rack, which one?
- x 1485
Re: '02 C5 steering rack, which one?
Hi Peter - welcome
There are at least 4 racks depending on engine, age and whether it's got variable assistance or not. If you post up the last 8 digits of the VIN we can look up which one is fitted. If only the pinion valve is leaking, it should be possible to just fit a new pinion valve - or even replace the seals.
Citroen want £1240 for one of the racks
- x 1056
If it helps with identification (assuming it's a UK spec model) only models with the V6 petrol engine on the mk1 C5's have variable power steering.
mcmoonter
The last eight digits on the VIN are 76317787.
Could you tell me where I might find the seal and pinion kit?
Thanks guys.
Thanks guys.
- x 1485
service.citroen says:
4000 LY
STEERING GEAR ASSY
MARKING 60DHGY 60LYBF 60DHLL 60DHJZ
This is qualified with : STEERING MECHANISM TRAVEL 148 EXCEPT DW12TED4 TURBO DIESEL
Citroen list the pinion valve, but
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT
00004048AK STEERING VALVE KIT 284.35 GBP 341.22 GBP 341.22 GBP
It might worth a chat with Plaeides in Sawtry to see if they have experience of rebuilding these?
4000 LY
STEERING GEAR ASSY
mcmoonter
Thanks for that.
