Hi all
On the display which shows your mpg etc
It appears the left hand lcd not lighting up?
Is this an easy fix??
C5 Estate 2.2 2001 model Digital
ej2095
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
- x 1240
Re: C5 Estate 2.2 2001 model Digital
Fairly, it has two bulbs in the back, one of them has gone.
ej2095
Cheers pete
Any idea what bulb and i take it i can pop out the display?
- x 1240
I think the display just pops out if you lever it, I think the bulb is a special one, I put an ordinary panel lamp in mine, it works but is not as bright as the other side.
- x 5671
Halfords, among others have the bulbs.
The display pops out with a couple of slim but blunt knives or spatula-like instruments.
Will do mine one day.
ej2095
Cool will have a play tommorow when light..
now for that sodding fuel cap warning lol
SaabC5
There are four securing tabs, two top two bottom. If you gently prise up the bottom two you can then pull away the whole surround. The display is held in by two torx screws, undo them and you can then access the twist fit bulbs (3) to change them. Refit is the opposite of removal but be careful of the TrafficMaster led bulb which has a ridiculously short wire
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
ej2095
Will have a look the weekend.
Car is parked on a main road and very busy in week with people bouncing past at break beck speed.
Any idea what bulbs these are and will grab some off good old ebay
SaabC5
Can't remember what bulbs they are from memory, but no problem with driving the car without the display so just go to your local motor factors and hand over the bulb for a match.
