C5 exhaust rattle
dnsey
x 19
C5 exhaust rattle
Unread post by dnsey »
My C5 II (2.0 HDi 16v) has an annoying rattle at times.
It mostly occurs under load, comes and goes, and appears for all the world as though the exhaust system is contacting the bodywork somewhere near the bulkhead. It sounds and feels too loud to be a loose heatshield, baffles etc.
I've had a good look, but the exhaust is well clear throughout its length, and I can't find anything else which might be to blame.
Has anyone else experienced this? If so, what did it turn out to be?
x 1488
Re: C5 exhaust rattle
Sadly the letters DMF spring to mind, closely followed by ££££ It's not a cheap job on this engine, and not easy if you do it yourself. It probably does it mostly at low revs just as let the clutch in? Does it also squeak when you turn the engine off?
Clogzz
x 40
Unread post by Clogzz »
My petrol C5 does that, it's something loose inside the middle muffler.
SaabC5
Unread post by SaabC5 »
Get it on a ramp and see if you can move it side to side to impact on any part of the underside. Also tap all the boxes to see if theres any loose parts inside causing the noise. Also check the rubber rear hanger to see if its split, the rear box can bounce up and down hitting the underside.
dnsey
x 19
Thanks guys.
I'm pretty sure that it's exhaust related rather than DMF, as the noise is more of a buzz, and occurs over a fairly narrow mid-rev range. If it was a spotier sort of car, it might almost be a desirable sound :wink: There's no squeak either, and I can't provoke it by mistreating the clutch when stationary.
It's got no worse over the 5k or so miles I've owned the car, but sometimes disappears for a while, particularly when the car's been up on ramps, leading me to suspect that the exhaust system has moved clear of something.
I can't get the exhaust to touch anything by shaking it, but will try tapping the boxes. The DPF was removed (for cleaning?) shortly before I had it; I wonder if the internals are loose?
