Turbo Electrovalve
dawsy 22
Turbo Electrovalve
Unread post by dawsy 22 »
Just a quick question what does the turbo electro valve do as I disconnected mine and it made no difference to the running of the car Cheers Ian
Thanks Ian
djadams
x 14
Re: Turbo Electrovalve
Unread post by djadams »
Depending on what car we're talking about here it allows the control of the wastegate (old diesel/most petrol turbos) or the variable geometry (variable nozzle) vanes in a more modern/high tech diesel.
If it didn't make any difference, there must be something up - most turbos will default to safe condition (wastegate or vanes fully open, minimum boost) when control fails.
2000 Xantia Activa 2.0 TCT (Danowned Activa :D daily driver)
1968 DS21 Pallas BVH (high days and holidays)
dawsy 22
Sorry about the lack of info its a 2001 C5 2.2 if the vanes were fully open would the turbo be louder than normal by that i mean they all have a bit of a swish to them but mine is a lot louder with very limited boost ,thanks for your reply I have had this fault for some time now and just cant find the cause Regards Ian
Thanks Ian
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
If there's no vacuum on the turbo it should be at full boost. The greater the vacuum the less it should boost. Maybe your's is stuck on semi boost? Might be worth a look at the turbo linkages maybe. Full boost permanently should throw an alarm btw. I agree that you should notice a difference in it
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
dawsy 22
Thanks Fellas that is my job for tomorrow I will report back
Thanks Ian
waynedance
x 8
Unread post by waynedance »
May I ask if stuck at full boost would that mean top end power but non low at low speed?
Volvo S80 D5.........
dawsy 22
waynedance wrote:May I ask if stuck at full boost would that mean top end power but non low at low speed?
I believe that is the case but mine is playing up and I am trying to go through things one at a time to try and ascertain where my fault is as I have said in previous posts it sounds like air is either blowing by or leaking I have checked for leaks and have not found any so now I am checking other avenues this all started when I changed the swirl diaphragm.Thanks Ian
Thanks Ian
