1.6hdi something strange??
Patriot1
Hi everybody, gotta bit of a problem with my uncles van. The turbo has gone due to oil starvation so I've replaced the cartridge assembly, only thing is the oil feed pipe is clear (removed banjo filter) in that I can blow easily down it with a finger over one side. I have removed the gauze filter from the pick up pipe in the sump and all is well until I cranked the engine over without starting it to check oil was coming through the feed pipe, when I cranked it over there was no oil so I took the pipe off at the engine end and tried cranking and still no oil pumping out of the block? Has anybody else had this as i presume this can be the only reason for turbo failure.. Thanks in advance for any replies
spider
- x 77
Re: 1.6hdi something strange??
Welcome.
Have a read of this topic > http://www.frenchcarforum.co.uk/forum/v ... =3&t=42948" onclick="window.open(this.href);return false;
Particularly this post > http://www.frenchcarforum.co.uk/forum/v ... 48#p351498" onclick="window.open(this.href);return false; see the links and the .pdf linked
Andy.
Patriot1
injector seals are fine and oil is new along with a new filter, i put the old bust turbo back on so i could run
the engine without the risk of damaging the new one and to see that oil would come out but still no oil
coming out the feed pipe hole in the engine block?
I took the oil filter out to see if oil was getting to it and it's as clean and dry as when i first put it in?
This makes me think that either the oil pump is bust or there is a blockage, thing is though the oil pick up pipe in the sump is clean and when i originally took the sump off it wasn't overly coked up.
addo
- Sara Watson's Stalker
- x 95
