207 oil gauge fault
Post Reply
assasukasse
My Cars:
207 oil gauge fault
Post by assasukasse »
Hello everyone,
I noticed from diagbox that I have a fault, defined as local, on the oil gauge..
I was unable to clear it, if I try to I get a page in french telling that I have first to read other faults on the engine and so on..
I do not have other faults to read!
The oil gauge seems working, I can see oil ok in fact, last week it told me oil low, so i added some oil..
So it is definitely working..
how to clear this error?
I am using diagbox 6.19.
Beside this I have also a "positive" permanent fault on the water temperature..
The gauge works perfectly...what should i do?
spider
My Cars: Soon, I hope...
x 77
Contact:
Re: 207 oil gauge fault
Post by spider »
I'd say do a Global Test which will check everything, then you may find out a bit more or be able to clear it.
Andy.
assasukasse
My Cars:
how do I do a global test with diagbox 6.19?
spider
x 77
Contact:
Post by spider »
When you choose the make / model it should launch Planet and from there you can choose the Global test.
Andy.
Post Reply
