gearbox identification
waveyr02
By the feel of it and from what i have read on here the clutch cable is just about to go on my synergie its a 1998 2.0 8v petrol, i just wondered if it is possible to identify the gearbox without actually crawling underneath or measuring the cable. It seems like there are three types ,BE3 ML or ME I think it should be BE3 but would be best to know before ordering on e bay. Thanks Simon.
- x 1490
Re: gearbox identification
Simon
It could be any of them.... post up the last 8 Digits of the VIN and we can check on service.citroen.
waveyr02
Hello Richard, numbers are 122530045 Thanks.
Ben82
- x 7
That's 9 digits? did you mean 12253045? For that one service.citroen says the following:waveyr02 wrote:Hello Richard, numbers are 122530045 Thanks.
TRANSMISSION BVM5
GEARBOX (CHARACTERISTICS) BE3 N
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 77
SPEEDOMETER DRIVE TACHO TORQUE 22X18
WHEEL STYLE OPTIMIZED WHEEL
TYRE (SIZE, TYPE) 195X65X15 T TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE BE3
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
waveyr02
Whoops, must have pressed 0 twice the number/details you have posted are right thanks, ill order a cable now.Thanks Simon.
waveyr02
OK not to keen on the price of these autoadjusting cables i wondered if anyone had fitted a manual one off another citroen model,the manual ones are much cheaper and looking on e bay some of the older models look fairly close dont mind adjusting clutch manualy and slight mods to make one fit.
- x 3296
It depends on where you get the cable. I had to replace one on Gracie just before Christmas, got it from GSF, and change from £21. Citroen wanted £43.
Where are you based? I have a spare cable (ok, it is for a Xantia HDi 90hp), and if it is suitable, maybe we can sort something out.
