I need to buy a torque converter citroen xantia 1998 v6 3.0 . No matter if used or reman. the reference is ZF 4HP20. if anyone know where I can get it please write me.
thanks
torque converter citroen xantia v6 3.0
Ben82
- x 7
4HP20 is the complete gearbox. And generally a failure of the gearbox most likely will be game over for a Xantia.
What has lead you to the point of needing to buy a replacement torque converter? (Or maybe the complete gearbox?)
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Mandrake
- x 695
Re: torque converter citroen xantia v6 3.0
It would also be helpful to know where you're located when trying to find one.
As Ben suggests, if the torque converter has failed there's a good chance that its done damage to the rest of the gearbox, or that the torque converter failed because of a fault in the rest of the gearbox, so either way, just replacing it without knowing the full situation could be unwise.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Maybe he's already found a box
the converter part number seems to be 2001.A3
