Can I please have some comments re this addition to the C5.
When you start the car is it in automatic mode or do you have to "turn it on"
When should the little green light come on, when you are in an area served by traffic master or when there is an incident. (should the green light always be on when in the area)
These new fangled toys....
Steve
Traffic Master
hswift
The system comes on in whatever mode you left it. Two pushes on the button toggles between automatic and manual mode. In automatic mode the voice will pipe up when there's a problem, in manual mode you have to press the button once to hear the message.
The light comes on -red or green - as long as you are in coverage range. The green light signifies no problems upcoming, the red light that there is a potential problem ahead. The light turns back to green when the system considers you're through the problem area.
