crusie control citroen c5 2004
Robert12
Hi does any body now how to turn on cruise control with a lexia any help thank you
- x 1056
Re: crusie control citroen c5 2004
You need to go into the injection ECU programming menu & set the option RVV to present, if I remember right there is also an option in the BSI menu to set the CC.
Robert12
OK thanks for that will have a gow tomorrow
Robert12
Hi wheeler found it in the injection and changed to present but can't find it in the bsi menu, its a forum members car
Robert12
All working now
boristhespie
- x 4
Do you not need wiring on the pedals for fitting this too or is it just the stalk?
C'est pas possible!
- x 1056
If your brake light switch has 4 wires on it you dont need anything else, if the brake switch has 2 wires you need to add an aditional switch.boristhespie wrote:Do you not need wiring on the pedals for fitting this too or is it just the stalk?
boristhespie
- x 4
I am stupid, so for what and where do I look?
C'est pas possible!
- x 1056
You need to add an additional brake switch if yours only has 2 wires, the extra connector should already be there, they are behind the passengers glovebox on the brake linkage.
