Just a thought, having taken my alternator off recently and hearing of problems with acessa to the timing and accessory belt area.
Being In France I found a set of these (a lot cheaper than this lot but not as good quality admittedly) http://www.castorama.fr/store/Jeu-de-5- ... ction=jump" onclick="window.open(this.href);return false;
Basically they are like a socket welded to a bent bar, needs to be the ones drilled through so a bolt can pass through the 'socket' bit. If not they can't tighten nuts on long threads because like a socket they run out of room.
A bit like an offset spanner but tend to have a longer reach in.
Could be one of the secret tools needed for french cars ? A socket and bar is too bulky for the space, a spanner does not reach around the obstructions.
May be available in the uk ? a good addition to the toolbox.
Spanners for french cars
charentejohn
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
addo
- Sara Watson's Stalker
- x 95
Sean602
Re: Spanners for french cars
I know there are a couple of jobs on a 2cv where they are brilliant , but generally don't do anything a decent socket set can do on a modern.
Not easy to find in the UK, usually the Facom set and they aint cheap! I picked up a couple of sets in the supermarket a few years ago but they are of the same sort of quality as a set of asda spanners ( pretty useless) Will prob get some better ones on the way to Spain this year.
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
orange 2cv
red Dyane( in bits)
- x 94
Sean602 wrote
"but generally don't do anything a decent socket set can do on a modern."
i would think they will get in a tighter space than a ratchet with a deep socket on,
gooogly search came up with
http://www.uktools.com/angled-socket-wr ... ?infoBox=0" onclick="window.open(this.href);return false;
Regards, malcolm.
Sean602
dunno, 3/8 seem to be able to reach most things trick is having a good selection of wobble extensions. anyway a few of those pipe keys are a usefull addition to the armoury.
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
charentejohn
Good to see that they are available in the UK, but the same scary price as they are here for a proper set.
Mine only cost about £12 for 14 sockets, not brilliant but good to have. Mine are the hex shaped interior rather than the 'serrated' ones, tend to get a better grip on sound nuts, especially if the sockets aren't top quality so a bit of play is not serious.
I have also seen clever hinged ratcheting spanners but again expensive http://www.amazon.co.uk/dp/B006ZL8DUC/r ... wo=&hvqmt=" onclick="window.open(this.href);return false; They would be useful on some jobs but I don't do enough to justify buying them.
Like a friend said, he is only sorry he has all the tools he bought over the years because there is so much clever stuff at the moment but he can't justify buying them.
Sean602
those spanners come up with the Lidl or Aldi badges on them every so often -and well worth the money! Just as long as you dont use them to crack the nut or do up to silly torque they are great for the likes of the top rear bolt on the timing belt cover or the A panel screws on a 2cv
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
