I'm just getting used to using Diagbox / Lexia, and thought I'd mention a couple of things which threw me to start with:
When the software is running through the diagnostics, the car behaves at times as though all sorts of scary faults are popping up - these are simply the various items being 'prodded', and nothing to worry about.
In addition, I've discovered that a diagnostic session can sometimes leave a spurious 'fault', bringing up the engine management light etc. Again, nothing to worry about, and disappears after a couple of starts.
Hope this helps someone in their first Lexia forays!
A note for new Lexia users
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: A note for new Lexia users
Thank you for the warning. I have recently got a Lexia/Diagbox, and I have yet to use it.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Ben82
- My Cars: C5 V6 2004
- x 7
I think the main ones that get faults to show are the abs and airbag ones.
So 3 in total if I recall
ESP/ASR not functioning
Braking Fault
Passenger airbag disabled
Some disappear before you look at the LCD if you're watching the Lexia.
Braking Fault
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
Teeheee, reminds me of the laugh we had running Diag "tests" on Toby's 406. mirrors flapping, wipers wiping, servos whirring, fans blowing, seats shuffling (with Toby sitting in it - thought he was done for as it moved him closer to the fascia/steering wheel with the headrest threatening to crush his neck) etc, etc.
Some of the actuator tests can generate spurious fault codes, for example on my Xantia if I use an actuator test on the engine ECU to test the rev counter (which makes the rev counter sit on 1500rpm for a few seconds while the engine is not running) the auto gearbox logs a speed sensor fault!
It's quite reasonable when you think about it though, as the gearbox is getting a signal from then engine to say the engine is turning over at 1500rpm but its own input shaft sensor says 0 rpm, which is only possible if you're in gear with your foot on the brake. In neutral the input speed should be nearly the same as the engine rpm, so it flags a fault.
There are a number of other combinations as well...best to check for the presence of real fault codes at the beginning of a Lexia session, so that you know any additional fault codes generated during your testing, especially actuator testing can be cleared and ignored...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
One thing with mine I've not been able to fix (does not really concern) using Planet the 'Scope' section I think always displays in French. Although I tend not to look at that section anyway as it does not serve a purpose with the limited use I use mine for.
Andy.
