Hi
It happened several times that when the pressure regulator ticks ( at least is sounds like ) the engine revs increases momentarily , now it happens more rarely . I noticed that at the time this phenomenon started the hydraulic pump started to leak. Can the engine revs be related in any way to the hydraulic system?
Zohar
Xantia -Engine revs and hydraulic pressure regulator
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
Chlorate
Re: Xantia -Engine revs and hydraulic pressure regulator
You'll notice it more if you ever try to jump start something - more current being drawn from the alternator means more mechanical drag on the engine, the engine speed drops a little so idle control kicks in and supplies more fuel to keep the engine from stalling.
Since the hydraulic pump is running on engine power it'll have a similar effect when the regulator/accumulator sphere wants a top up (when it ticks) but not quite so noticeable. I've never actually noticed mine doing this, or paid close enough attention.
Alex
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
- x 94
its not quite like that, its more a case of the engines normal idle speed is slowed/dragged down, when the alternator regulator or hydraulic pump regulator kick in
Regards, malcolm.
lancia58
- x 8
It was quite noticeable I guess the revs increased by 200-300 RPM
Zohar
Zohar
