Xantia XUD cam sprocket alignment variants
John Plum
x 5
Unread post by John Plum »
Q: :( I encountered a problem in setting the timing of the camshaft on my XUD. I am not sure of the correct alignment position.
Generally XUD's are aligned at about 2 o clock. HDi's are about 7 o clock.
At about 2 o clock on my camshaft sprocket, there is an a`adequate threaded hole in the engine casing behind, to take an 8mm bolt.
At about 7 to 8 o clock behind the cam sprocket, is a hole in the engine casing, but blocked from recieving the 8mm bolt, by a pressed in ball bearing.
I suspect the last one is the correct alignment position to the alignment hole in the cam sprocket; do I have a variant to the normal XUD?
Is anyone familiar with this design?
You could read more about my discovery upon strip down here:
http://www.frenchcarforum.co.uk/forum/v ... 72#p361372
Cheers,
JOhn
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
spider
x 77
Re: Xantia XUD cam sprocket alignment variants
Unread post by spider »
I seem to recall the pressed in bearing is just that, I know what you mean my 205TD had that as well. Its a sort of blanking plug in a way.
The timing hole should be obvious as its quite deep in effect and you can screw a bolt into it too.
Andy.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
John,
XUD Timing pins are NOT at 2 oclock.... they are timed at 5 O clock!!!
A very sad...
1994 XM 2.1 d auto
John Plum
x 5
Yes gotcha on that- all was sorted. You're quite correct.
I had been misinformed by one post, probably because it wasn't clear; just chose the wrong one as a guide.!
Sent from a mobile transmitter.
John Plum
