First of all I'll apologise in advance for my lack of 'Forum's' knowledge & etiquette and my poor mechanical knowledge in case I've logged this request for help in the wrong place or describe the problem badly.....
I bought a 2001 Xantia Hdi LX 90bhp Estate a few weeks ago. I've had GSA, BX, XM and Xantia's in the past and initially all appeared well with this car. The hydraulics appeared sound, rising as required, brakes and steering were responsive with no apparent leaks. However, last week, having covered only 150 miles and on a hospital visit as I entered the car park I got the red STOP sign on the dash and parked the car. Unfortunately I didn't look to see what other lights were on..... The steering at this point was OK.... 3 hours later I returned to the car to find a pool of green LHM oil on the ground. I put the key in the ignition, STOP light on & no movement in the steering. On advice given by my garage I got some LHM & put in 1.5ltrs to bring float between the lines and limped to the garage.
The garage said it was a leak on the corroded pipes leading to the power steering unit. - The removed pipes were about 2 foot long with a spaghetti junction shape (Sorry, best I could come up with).. Since repair, (Innediately on leaving the garage) the steering is very bad. When stationary with the engine on and turned on full lock the steering is vibrating / shaking very very badly. There is a growling type noise on the movement. When not on full lock it operates, but not ideal. The brakes are shuddering even at slow speeds, though it is not heavy shuddering. The car is very bouncy and difficult to handle and lastly the hydraulic rise will not operate at full height, with the front of the car settling down very slowly when ignition switched off....
I know that's a lot of stuff, but the car is going back to the garage next week and I'd like to be a little wiser as to what might have happened / gone wrong when the pipes to the power steering were replaced... Any advice greatly appreciated.
Xantia HDi Estate steering, brake & ride problem
- x 94
Re: Xantia HDi Estate steering, brake & ride problem
hi Rosetti and welcome
were are you located
first thing to do is with the car on level ground, put the height lever to the highest setting wait for the car to stop rising, then check the citro blood level indicator on the tank is between the two red bands,
also at this stage is the STOP lamp on, if it is or the car does not rise fully top up the level a bit more till the indicator is between the two red bands,
once your happy it has enough citro blood and with the engine running turn the steering hard lock to lock a few times, then re/check the cito blood level again,
if this does not sort it, with the engine running open the 12mm bleed valve on the front of the regulator, and hold the revs at around 2.500rpm for around two min's, then shut the bleed valve,
then report back
then report back
Regards, malcolm.
- x 3306
Hello Rosetti, and welcome to the forum.
If you do as Malcolm says, you should find that the problem will clear up. The problem is (almost certainly) due to air in the system. The only thing I would add to Malcolms' advice is (once the steering and suspension issues have gone) to bleed the brakes.
- x 1488
I wonder if they've replaced the PAS feed pipe which is part rubber / part metal with a solid line? The rubber part absorbs the pressure spikes from the pump, and may well give the symptoms you describe (for the steering at least) if it's missing.
Rosetti
Hi Thanks for all that. I'm in Newcastle upon Tyne... Although when I bought the car the suspension rose and settled as it should, since the repair work it won't go to full height it just stays put. I'll certainly give the advice a go tomorrow, but if it won't rise I'll be reliant on the garage. As for how they've repaired the pipe I'm not sure, I'll have to ask, but I'm certain it was metal parts, but also sure that they discussed fitting some kind of joint (???) to make everything compatible. What exactly that means I'm not sure, I'll have to ask.... Sorry if I sound so ignorant, I'm just not mechanically minded enough, but I greatly appreciate the advice and I will stand in front of the mechanic on Tuesday coming and try and get the information from him that I may need.... Thanks to all
neil123
If you're in Newcastle... top tip would be to take it to Michael Bonello at Bonello Auto Services, on Stepney Bank (head towards Byker Bridge on New Bridge St, turn right immediately before Tanner's Arms pub and then immediately left, down the bank behind the pub - the garage is 50m on your right)
The man's a genius, and although he also restores Alfas, is a Citroen guy through and through. He's a nice bloke, completely honest and genuinely expert on hydraulic Cits. He's also got a particular soft spot for Xantias.
Even if you don't need him this time, I'd recommend seeking him out now, for when you do!
He's on 0191 2616430. I have no connection with him other than as an extremely satisfied customer, with friends who are also customers. mention Neil and the red Xantia estate (he's just fixed my ABS and changed the air mass meter).
Hope that helps!
Hope that helps!
- x 5674
Rosetti
Thanks Neil, I might just give him a ring... My garage is really good, but don't think he's up on Citroens. Don't think he'd mind me saying that. He did mention of another Newcastle garage in the West End I think by the name of French Auto's or French Cars.... I know Stepney Bank pretty well, used to work in Byker and no problems getting over there so thanks for the info.
