C5 rear struts query (push rod)
citrokid
Unread post by citrokid »
I have a C5( 2005 1.6 hdi) where one of the gaitors is perished, I know i can get the gaiter as replacement but my query is can the push rod also be got separately ?
There is a quite a lot of play in the push rod knuckle so the reason to replace !
x 94
Re: C5 rear struts query (push rod)
Unread post by citronut »
there will be play in the knuckle with not suspension pressure,
,if you send me the last 8 digits of your chassis/VIN No. i will get the part No. for you just in case there is wear in it
Regards, malcolm.
citrokid
citronut wrote:there will be play in the knuckle with not suspension pressure,
76645355
thanks
